Old-Biscuit
Jun 26, 2014Explorer III
The 'regular' flush is no where near the same as a residential toilet.
We have a sprayer and use it a lot, helps spray down bowl top to bottom, use it to clean seal/blade valve, spray down throat of toilet drain line, rinse the bowl of cleaner etc.
Very handy.....and it's just a 'kitchen sink' type sprayer so easy, cheap to install (just goes on a small stub area of water valve assembly----drill hole thru stub, secure hose with screw clamp) and there is only water pressure on the hose/sprayer when you operate flush valve.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
