MEXICOWANDERER
Jun 13, 2017Explorer
If they are built like the Megawatt no weak bi-polar transistors. MOSFET finals. I dumped the Gigawatt into a 10 volt load. 64 amperes. It has 160 amperes of schottky rectifiers.
From
eBray...
"Size Name:DC 0-48V 10A Parameters: Input voltage: AC 110-220V ± 15% Output: DC 0-48V 10A Rated power: 480W Product Dimension: 21511550mm (lengthwidthheight) Wiring: ?: Ground N: Null wire L: Live wire V+: DC output + V-: DC output - Instructions for use: The current is unregulated and max. is 10A. The actual current is decided by load. Any devices below 10A current can use this product. Any devices above 10A current cannot use this product. Note: If use motor, fan and other inductive load, please pay attention to the load’s maximum starting current parameter. This parameter shall not be higher than the power supply’s max. current. Otherwise it may damage the power supply. Or allocate the soft starting protection circuit for the load to absorb the impact current."
Let's see what DROK doesn't say...
From
eBray...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
