time2roll wrote:
I want to know how the manual knows where to put the sensor...
What did the engineer do to determine placement?
He called me:W Doug- I want to know how the manual knows where to put the sensor...
What did the engineer do to determine placement? - FreightguyExplorer
dougrainer wrote:
I only posted this because it shows where RVP wants the sensor and the PITA posted where Dometic wants the sensor. Now he has the old conundrum----A man with 1 watch knows the time, A Man with more than 1 watch will never know the correct time. Doug
https://www.airxcel.com/DesktopModules/RvProduct/Pdf/t007.pdf
BUT, you proved it! Which was the whole point of the post, NOT to instruct where to put the sensor but to prove it. Thanks for all the kind words. - I only posted this because it shows where RVP wants the sensor and the PITA posted where Dometic wants the sensor. Now he has the old conundrum----A man with 1 watch knows the time, A Man with more than 1 watch will never know the correct time. Doug
https://www.airxcel.com/DesktopModules/RvProduct/Pdf/t007.pdf - TvovExplorer IIWell, I was bored and looking for an interesting thread, and I found it! I am not sure about the title, the original post has been edited, and odd posts follow fast and furious!
Now I have to go find a Walmart camping thread... - Travelin2Explorer
drsteve wrote:
RLS7201 wrote:
Freightguy wrote:
dougrainer wrote:
Freightguy wrote:
So the consensus is, opinions without proof.
40 years as an RV Tech and still working. MY explanation IS NOT an Opinion. IT IS FACT. Doug
Sorry but the question wasnt where does it go, it was can you prove it. No one has provided any documentation.
Now your're steeping on the wrong toes. What Doug states is FACT!
The man gives the best answers of any one on the forum.
Richard
X2. Doug's answer IS documentation.
X3....Doug has helped me on several problems I couldn't figure out.
What he says, you can take to the bank. - marcsbigfoot20bExplorer
wa8yxm wrote:
WHat freon. Have not used Freon in years REFRIGERANT (Freon is Refrigerante Number 12 by the way).
If you can not find the installation manual for your A/C about 2 inches up from the bottom of the Evaporator about 1 inches left of the right hand edge.
(Lower right corner in short). That is GENERIC however. Your manufacturer may suggest elsewhere
“Freon” is a registered TRADEMARK and brand name.
Freon - drsteveExplorer
Richard
X2. Doug's answer IS documentation. - RLS7201Explorer II
Richard - So did that resolve your freeze up problem?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
