grizzzman wrote:
cannesdo wrote:
grizzzman wrote:
cannesdo wrote:
time2roll wrote:
With no solar four batteries will generally last 2 to 8 days depending on usage. If solar tops them off every day you run indefinitely.
and run only my tv it only lasts a few hours then my battery indicator is showing the power has dropped. That is the case whether the batteries are new or older. My 4 batteries will get me through a night at a truck stop at best. ?
Am I doing something wrong?
I fear it's the former and my batteries are nearly dead. fluid is ok does that just mean the batteries are in bad shape and will soon need to be replaced?
1. Yes you are
2. Yes they are
3. Yes they will
4. To bad you have no entrust in solar. Installing a "system" would relieve you of battery duties so you could get back to camping.
C'mon....I have *concerns* that it won't be enough for me based on what I've experienced so far. Maybe you could recommend some batteries or other fixes to improve my situation rather than setting down a snarky "You're doing it wrong" and walking away.
And I'm not camping. I'm living and working full-time in this space which is why I think perhaps even the best "system" may not be enough for me.
It sounds like I have to choose to go with batteries that will work well for me if I'm running on solar all the time or batteries that are best suited to constant shore power. If I pick one then do the other my batteries will be damaged so doing some of each doesn't seem like much of an option.
I simply answered some of your questions. I do not agree with name calling. It appears you do? I have been sitting in this chair and since I'm responding I have not walked away?
OK here's a question when was the last time your batteries have seen "over" 15 volts for a few hours? Do you understand what sulfation
Is? And it's the number one battery killer in RVs?
Do I have your attention or are you still mad at me?
1. It felt snarky.
2. "snarky" modified an action of a person and not a person so it is not name-calling.
3. "Seen" could mean any number of things.
4. I do.
As I have stated I have been plugged in, aside from a few short road trips, since the batteries were new. I have tired to run on battery power with the inverter and found they were too low to give me power. I have not, to my knowledge, done anything that would cause sulfation. I am not aware of any time that the batteries were too low and I was only unplugged and on the road about 5 times and plugged in if I had to pull in somewhere for the night.
