MEXICOWANDERER
Aug 19, 2015Explorer
A big bus? Ah come on. The owner is going to change oil. An Allison with problems will have its fluid changed probably twice trying to cure the problem.
Note: Big diesels can develop coolant leaks. One is called a "cold leak" when parked. The 2nd is a "hot leak". Pressure testing the cooling system can reveal a lot of problems including heads gaskets leaks. A cylinder Leakdown Test reveals compression issues.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
