BFL13
Sep 13, 2019Explorer II
lenr wrote:
Don't know if it is true for all AGMs, but Trojan T-105 AGM says do not equalize. I believe that periodic equalization is Progressive Dynamics big claim to fame with the charge wizard. I would choose a converter that allows setting the maximum voltage.
The PD "equalize" is not the same thing as what the AGM advice is warning about. All the PD "equalize" does is give a shot of 14.4 every so often amongst its 13.2 storage "stage" It really should be called "destratification".
In fact you do "equalize" an AGM if needed, except they call it "conditioning" and maybe not to such a high voltage as with Wets. Say 15.5 for an AGM vs 16.2 for a Wet.
It depends, as usual.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
