SoundGuy
Sep 14, 2019Explorer
RKW wrote:
FYI to the forum, 90% of the time my RV will be sitting on the pad and connected to shore power and in 20 years of RVing I've probably only boondocked 10 times and all those were just overnight.
Considering your intended use I see no need for such a large capacity battery when a G24 would suit your needs 90% of your camping time. Having replaced my aged flooded G27 Interstate with a G31 AGM from East Penn I'd recommend an AGM that requires zero maintenance, other than periodic recharging of course. Size, your choice and how much you want to spend - G24, G27, G31 - but even a G24 should get you through an overnight stay. That, and the fact that in a pinch you can always draw from your tow vehicle as long as you keep that draw minimal. I also keep a small lithium battery jump starter in the truck in the rare case I might have pulled the truck battery down more than I should have, an example being the NOCO GB40 Jump Starter.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
