- lenrExplorer IIII'm going to start a new thread instead of further hijacking. Thanks for the replies.
- BFL13Explorer II
lenr wrote:
Help my education: why is it especially important for AGMs to be charged at 14.4? 4 hours at 14.4 was mentioned above, but my Trojan T-105 AGM manual says to limit 14.4 absorption voltage to 2 hours. It does say to use a constant absorption voltage of 14.4.
Thanks.
First they say to keep it at 14.4 until amps taper to 0.5a /100AH of battery capacity. Then they say to limit the 14.4 to two hours? How do they know how long it will take to get to 0.5a ???
Also, the T-105 AGM is still a 6v batt, so it takes two to make 12v and that is about 220AH or whatever the AGM version is instead of the Wet's 225. (I forget the AGM number) so it will take a while to get to 1.0a for the 220ish AH. More than two hours!!!
IMO forget that, and go for the proper 0.5a/100AH and never mind how long it takes. - pianotunaNomad IIIlenr,
You should follow the maker's recommendations "to the letter".
Not all companies are specific--so 14.4 is a "safe" number for most. - lenrExplorer IIIHelp my education: why is it especially important for AGMs to be charged at 14.4? 4 hours at 14.4 was mentioned above, but my Trojan T-105 AGM manual says to limit 14.4 absorption voltage to 2 hours. It does say to use a constant absorption voltage of 14.4.
Thanks. - MEXICOWANDERERExplorerYep and how about power post and home recovery ability? Most garbage can't acheive it connected for 1,000 hours
- RKWExplorer
red31 wrote:
Wow, 4 hrs at the push of a button. Longer than generator time, nothing new!
I think the important thing, especially for AGM batteries, is the ability to prompt the charger to a 14.4 volt output. - red31ExplorerWow, 4 hrs at the push of a button. Longer than generator time, nothing new!
- MEXICOWANDERERExplorerWell said LY318
- landyacht318ExplorerIve installed more than one pd9245 delivered here in california with the wizard. The measured voltages at output were slightly above specs. And pushbutton 4 more hours of 14.56v is a great feature, however no doubt some will stomp their feet at the temerity of a product forcing them to do anything.
- RKWExplorer
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 17, 2025
