BoonHauler
Jan 16, 2015Explorer
coolbreeze01 wrote:
Last plumber used pipe dope over the tape. Claims his fittings don't leak.
This is what you do, pipe dope then tape. You also dope the other fitting as well.
Works great and never had a leak.
coolmom42 wrote:ScottG wrote:
Clockwise. Otherwise as your threading something on to it your unraveling the tape.
Or you could just use pipe-dope and not have to remember!
Generally.
But flammable gas cylinders (all I've ever seen) are threaded backwards. The nut to connect the cylinder to a hose will have a notch in it. So the tape goes counterclockwise.
So the tape goes in the direction that won't unravel it when you make the connection.
You NEVER use thread tape on a POL Spud Nut.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
