RoyB
Sep 27, 2016Explorer III
We used to clear some fault codes by disconnecting the battery terminals and then pull a light switch ON for a short time... This will drain off any residual current that may reset some settings... Used to work great doing this clearing code messages etc.
However a couple of years ago I had to replace my Truck Alternator one time so pulled the battery terminals and pulled the alternator and off to NAPA I go. Came back with rebuilt alternator and got it all hooked back up and things ran good but my idle setting was way off. My engine would die if I took my foot off from the gas pedal at a stop sign. I drove it awhile this way for a couple of days as the book said it would re-learn its setting again...
Finally had to take it in to be put on the Ford Computer at a minimum cost of $90 an hour. It took about five minutes to reset all the settings and things were just fine after that. Still had to pay the $90 service charge for the five minutes of work...
A better for Ford idea I reckon...
Even today if I have to pull my Truck start battery terminals for any reason I always throw in a second 12VDC source to keep the computers still going...
Will work hard to keep from throwing away another $90...
Roy Ken
Roy Ken
