map40's avatar
map40
Through-The-Roof sealant
I applied on my rubber roof and over the shower skylight. The skylight was cracking and put a 1/4 inch layer of the stuff. The rubber roof did great. Easy to apply. Anybody else used it?
  • One of the units went under a tree and a branch hit the skylight. The plastic got destroyed, half came loose. Yes, the dome bounced back in shape BEING SUSTAINED ONLY BY THE STRUCTURE OF THE SEALANT. I put some pre-peg UV fiberglass reinforcements and another coat of the sealant. I am sold on this stuff.
  • YES! I like Through The Roof sealant, but I don't use it in any quantity on my roof. Use it instead of a silicone type caulk on seams, etc. I apply it with a small artist-type paint brush.
  • Read the manufacturer's technical data sheet and it clearly warns that use on EPDM rubber membrane "may cause warping" - exactly the reason a product like Dicor self leveling lap sealant which is designed specifically for use on EPDM should instead be used. ;) Why try to reinvent the wheel when a proven product like Dicor is so readily available? :h
  • I've seen it advertised but, never tried it. I use Heng's Rubber Roof Coating, even on the skylight.
    Keep us updated on how your stuff holds up. It has good reviews on Amazon.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
