westnavy's avatar
westnavy
Tilt bed controller
My tilt bed controller is only raising bed about 6 inches then it seems that it’s amping out ( no further movement up/down), until I reset the configuration button. I contacted mfg and they’ve been little help. Do these controllers fail in this manner? How much are they to replace?
1 Reply
  • The controllers do go bad every so often. I just replaced my Lippert controller with a new one for $109. Also check your wiring beneath the bed. Sometimes a wire to the motor or switch breaks or come loose causing the problem. If all the wiring looks good, it's probably your controller.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
