ajriding's avatar
ajriding
Explorer II
Aug 30, 2019
Tilting Solar Panel
I did a little experiment.
I have a new poly 100 watt panel. Before installing
I tilted the panel to face directly into the sun. 19.6 volts.
I tilted it the same angle, but away from the sun, so at a very bad angle to still have sun hit it. 18.4 volts, was not that less of a tilt to be 19.6 (1 volt less).
I tilted it to be in the shade, only ambient light. 17.x volts.
I don't feel so bad that the panels lay flat on the roof. The bad angle was about 5% less volts. Shade was 6.x% less volts.
The controller will drop the voltage down to 14 or so, but amps will still be lower, probably 5% too.
5-6% is not bad for being able to just lay the panels flat. I see RVers with rigs where they can angle the panels perfectly and get that 5%, maybe they need it.
Am I missing something?
  • There is a video on youtube, "What effect does tilt angle have on solar panels?" By the altE store. She comes up with numbers that are a lot different. Interesting video worth watching.
  • I view tilting panels on the top of an RV as lots of work. Easier to add anothe panel IMO. Good report!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
