Acei
Oct 22, 2014Explorer
Thanks for the feedback guys.
Although those Magnum inverter/chargers are expensive, looks like an elegant solution. I only found a model called MS4448PAE which appears to be equivalent to what was mentioned above and each cost about $2200.
Adding to this picture, what happens if I add NINE 160w solar panels? Can I still use the same components?
My daily usage is expected to be around 370Ah (I realize it is a lot) and obviously, those panels isn't enough to cover my usage hence I'm going to be using a generator during the day. I'm thinking a quiet Honda 3kw generator - it appears to be the quietest generator at this rated level. I cannot keep the generator on 24/7 and shorter time the better.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
