horizon36
May 31, 2016Explorer
Shut down all power, unplug the RV. If you have solar pull the fuse/turn off the breaker. Take good photos of the wiring and if at all possible label the wires. Remove the ground (-) to the coach first then the other negative wires off the bank. At that point you should be safe. Clean all the cable ends with a wire brush. Reverse the process to install the new batteries and spray the terminals with anti corrosion treatment (found at auto parts stores). The last connection is the main negative/ground wire to the RV.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
