zach477
Oct 02, 2015Explorer
enblethen wrote:
Remove cover from the thermostat. connect the two furnace wires together. The furnace should start the fan and produce heat. Separate the wires and furnace should go into cool down mode.
If this happens the thermostat is the problem.
Did you check for on off switch on thermostat.
Do you mean the control panel? Or the little thermometer on the wall?
Also, I have two temperature sensors, but I don't have different zones on the control panel so I'm not sure why there are two? Could one be for AC and one for the furnace?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
