zach477
Oct 02, 2015Explorer
enblethen wrote:
You can do the same thing at the furnace. Two wire in unit commonly blue. Connect a jumper there.
Your light on furnace would indicate that it is getting signal from the thermostat. Try spinning the fan with power shut off to see if it spins freely.
Model of furnace?
Is there a small circuit breaker on the fan housing? Should have white or red button to reset.
Right, so if it's getting signal, its not the thermostat.
The fan spins freely when I use my hands.
When measuring voltage to the fan, there is none.
It's an Atwood 8535-IV
It has a Circuit breaker, and I have tried resetting it multiple times.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
