westend
Oct 02, 2015Explorer
I'd suggest to bypass the circuit breaker, manually. If you remove the two wires from the circuit breaker, set your thermostat, wait for the green light then touch the wires together to make contact. If the blower turns, the problem is the circuit breaker. If no blower turning, the problem is probably the fan motor.
If you are able to power the blower by bypassing the circuit breaker, don't run it like that. Replace the breaker with a better one. There is a reason the breaker failed and if it's because of a fault in the motor, you don't want a bigger problem to fix.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
