turbojimmy
Oct 03, 2015Explorer
enblethen wrote:
You will need to check for voltage. Check the circuit breaker to insure it has power coming in and then output to the motor.
I was thinking the same thing, but the diagram - if it applies to his unit - shows the breaker protecting the whole shootin' match. BAsed on the diagram, there wouldn't be a green light on the board if that breaker was bad.
Even so, I'd bypass the breaker and/or check for voltage on the other side of it.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
