zach477
Oct 03, 2015Explorer
Chris Bryant wrote:zach477 wrote:
My Atwood furnace worked great when I tested it before buying the coach...
As I turn the thermostat up, I hear a "click" from the furnace, and I can see a green LED on the furnace circuit baord come on. So no error codes, and since it seems to be triggering the furnace to "come on", I'm assuming the thermostat is working. Correct?
Thanks
My info says that a solid LED on that board means internal board failure- the only Atwood board I know of with an LED is a fan control board, and my chart give error codes for solid on , 1 flash, 2 flash, and 3 flash- they are all errors.
I was under the impression that it was a red LED that indicated an error. Mine is green. That's still an error?
Also, I just noticed that it is a DInosaur board. Does that mean its an aftermarket circuit board or would that come stock?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
