zach477
Oct 03, 2015Explorer
Chris Bryant wrote:
A solid green on a Dinosaur means the sail switch is stuck closed- it's attached to the plastic blower cover, inside. The board knows it should not get power through the sail switch if the blower is not energized, so it doesn't start.
From the directions at http://dinosaurelectronics.com/Instructions/Fan50PP_inst.pdfIF!? For some reason the fan does not come on and the GREEN LED is lit on the
circuit board, the sail switch is stuck in the closed position. The Fan 50 Plus Pins
is designed to stop and do nothing if the sail switch is stuck closed.
Nice! I'm glad we got that figured out!
Seems like something fairly easy to fix? Or will it just get stuck again next time?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
