MrWizard
Dec 20, 2020Moderator
He mentions both devices, the CO detector and the lp control Pre tell, the CO detector does not control anything but misbehaving indicates a problem, I think he has 12v power problems, I think the house batteries are not getting charged , and low voltage is his problem needs to check and clean house battery negative main ground, maybe replace cable, check and make sure the house battery is charging when engine is running,
Don't know why a 19ft RV with out OEM built in generator would have a CO dectector
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
