dougrainer
Dec 21, 2020Nomad
IF other LP appliances work, then the LP detector and system is functioning. The OEM's stopped installing the 12 volt solenoid LP detectors almost 20 years ago. You remove the 12 volt shut off solenoid at the LP tank and just install a standard LP detector. Doug
