30sweeds
Mar 26, 2022Explorer
The 3d line is for the evap system,an emissions thing.On the pump...buy the pump only kit with the screen,wire harness,seals,and install it on the original housing.If you use the whole assembly like you bought,odds are the gas gauge will be off and the pick up tube will be the wrong length.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
