30sweeds
Apr 04, 2022Explorer
Nice write up! My fill and vent hoses are 1 piece.I cleaned them up with some lacquer thinner and they will be OK.The parts store replacement filler is too thick and not pliable enough to work.
My main concern with the tank removal was spinning out the heads of the carriage bolts on the passenger side.Driver's side has U nuts over the frame and the bolts should come out.Nothing was real rusty.I do have a transmission jack that should work but I guess I will have to struggle with the rest of it like you did.
I think I mentioned in a previous post something about the gas gauge not being correct with the complete pump and housing replacement.The fuel pickup might not be low enough to suck much gas with 8 gallons.If that vacuum line is pinched , disconnected,or damaged,it will throw a fault code but the engine will still run OK.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
