westend
Apr 27, 2015Explorer
acritzer wrote:westend wrote:
All good advice above. As mentioned, the real trick is getting the correct amount of caulk on the joint. Spoons work good for rookies. If I had to recaulk all the siding joints on my trailer, I'd be done in less than 1/2 hour. This isn't a tough job.
Just the walls? Or including windows, hatches, doors etc?
The whole shootin' match.
Here's the deal--I'm a caulking fiend. I paint a few houses a year, lately a couple a year. I figure if the customer is paying me a fair amount for painting, he deserves to have all his siding caulked. I've always done it this way. It's pretty much SOP to dump a half a case or better of caulk on the kind of houses I do.
A trailer or Class C should eat up about three or four tubes and you only have to climb a six foot step ladder. Since I went to Eternabond on the roof and Geocel 2350 on the siding, I'm anticipating very little in the way of sealing.
Here's a tip for you if you're using the polymer caulks like Proflex or similar--warm the tubes up before you apply the sealant. It will come out of the gun better and is a easier to tool a good joint.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
