MrWizard
Jun 04, 2015Moderator
you do have shore power un plugged
while testing for generator power... yes
the interlock will prevent transfer
if you are testing correctly, then the answer is the little control board in the transfer switch is bad
or the relay coil for that side of the circuit switch is burned out
either way.. its time for a new transfer switch
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
