profdant139's avatar
profdant139
Explorer II
Feb 26, 2019
Tire chains: ok to cut off extra links at end points?
I just got a new set of very heavy duty snow chains. I know I will probably never need them, but you have to carry chains in Calif. in the mountains, and there might be times when I am in the back country during a snow storm.
These are real chains, not cables. When I put them on in my driveway and tightened them up as much as I could, there were a couple of extra links at the end points, both inside the tire and outside. These are at the places where the hooks meet the other side of the chain.
I am a little concerned about these extra links flopping around and hitting my wheel well -- there is plenty of clearance, but it still looks like it could happen.
So I am asking experienced chain users -- is it ok to cut off some of that extra chain? Or should I leave it on, in case I need extra slack while installing the chain under difficult conditions? (I understand that once the chain is on, you roll a little bit and then take up as much slack as possible.)
Thanks in advance for your advice!
  • My plow truck has all 4 wheels chained up and all have extra Link's which are secured to the opposite side of the chain by good bungee cords. Have been doing this for 11 years. You might want to sell them somedayto someone who has slightly bigger tires. I have 4 extra Link's on all 4 tires Leave the extra links.
    Dave
  • Leave the extra length there may come a time when you'll need it. Tie the extra links off. I always use wire not cable ties as wire is stronger and less likely to break
  • Yes, you can cut extra links but leave at least two. Carry cable ties to secure flopping links back to other links.
    Make sure they are the correct size for your tires before cutting.
  • If the tires are brand new then yes. Although I would still leave one. In difficult conditions you may want some slack to get them on. Once you roll 100 yards they may need tightened but at least you have them on. If you have them on a few times and want to cut that last link then fine.
    If the tires are a bit worn and you get new tires next year you might be looking for those extra links. Put some wire in with the set of chains to tie them back if needed.
    I would leave one or two max.
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 03, 2025
