Tal/IL wrote:
jjrbus wrote:
So I go and get rig weighted and inflate rear tires to 10% over psi suggested in load and inflation tables.
I DID NOT HAVE A TIRE FAILURE. I keep getting told to run tires at much higher pressure in case I get a blow out, makes no sense.
Your tire failure may have been totally unrelated to air pressure. Still, I am curious: how did "10% over psi suggested in load and inflation tables" compare to sidewall max pressure?
In my mini Toyota sidewall max psi is 65, load and inflation table load range D tire calls for 39 psi, I run 43 and use TPMS.
