swimmer_spe
Jun 27, 2021Explorer
Tire placard
I feel silly asking this, but i don't know where the sticker is that says what my 1999 Rockwood Ultralight 24' tire pressure is. Where would the sticker be located?
I will wager that your RV states to fill to the tires MAX sidewall listed. Why, because that's how they determine carrying capacity.
Now if you want to use the brain that God gave you go to the scales fully loaded. Now take that axle weight and divide by two. Compare that to the weight/inflation chart for your tire. Let's say the chart says 70Psi simply add 5 psi to that number. By doing this it will give the best ride, best stopping and best tread wear.
But then you can do like many others and simply air to the MAX on the sidewall or whatever the RV states.
