RCMAN46 wrote:
Pressure Pro makes a very good system.
The Pressure Pro has two advantages over the TST that should be considered.
1. The Pressure Pro will alarm you of a lost tire sensor signal in less than 15 minutes. The TST will take 1 hour.
2. The Pressure Pro has a feature that lets you measure the signal strength of the tire sensors. This information will help you determine if an external antenna (the best method) or a repeater is necessary.
Last the Pressure Pro does have temperature alarms but does not display the temperature only an alarm when temperature is greater than 210° F.
x2
Am looking into Pressure Pro (made in the USA) to replace our TST's. I've been e-mailing back and forth with Steve Berry (CEO of L&S Safety) and his answers have been very enlightening.
Sensor loss and how/when it shows up (or doesn't) is actually a monitor issue. TireMinder is coming out with something that may help with that. TM also gives you a repeater/booster with every system they sell, which is nice.
We're also checking into
EEZRV. They seem to be getting very popular.
Btw, haven't seen or heard the word "
slumgullion" for ages. Wow! :)
(EDIT: Not an Advert or Endorsement)
