bob213 wrote:
My TST 507 is great. It does not include the psychic ability feature that can predict a blow out. If you have tread separation and the tire does not deflate it can not tell you that either. A rapid loss of air pressure or high heat, it reports well.
When we came home and parked we discovered that we had a problem. Tires looked absolutely fine, no pressure loss. But neither of the X-chocks would fit on one side which was very strange since they were pre-adjusted and interchangeable. I looked everywhere for a problem but could not find anything. Took it to a frame shop and they replaced some spring bushings but knew they hadn't found the problem until they measured the diameter of the tires. Two tires on the street side were larger in diameter then the other two on the curb side. But the tires looked fine to them too. I took the rig to my favorite tire shop and the problem became obvious only when the tires were dismounted. Iit took no special skills or tools to see that two of the four tires had lost their integrity. Those tires probably hit something, got damaged, and were ready to blow. Lucky me! And I'm careful with my tires - don't roll over curbs or cut corners and I try to avoid potholes.
So how can I realistically expect a TPMS system to detect something that myself and several experts cannot readily detect. No, I don't have a TPMS system, not yet anyway, but it sounds like a good tool to have onboard. Although tire pressure was never an issue, It might have discovered some excess heat being generated.
