loggenrock
Oct 31, 2016Explorer
I gotta put in a plug for rig weighing, not just on a CAT-type scale, but by wheel position. Had it done this summer and it was a real eye-opener. Even though I was near my GVWR, turns out I was well-UNDER for each axle. By knowing the actual weight at each wheel position, I was able to LOWER the pressure in my tires from sidewall max of 80psi ( which I incorrectly thought I needed based on overall vehicle weight) to 60 in the fronts and 65 in the rear duallys. End result will be better ride comfort and increased tire life. Actual tire psi's are based on each axle weight in addition to the tire manufacturers weight chart. ST
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
