pianotuna wrote:
Hi,
I don't have a good understanding of tire pressure vs ride.
I have been using what is on the inside of the driver's door.
i.e. 65 lbs front and 80 rear.
Should both front tires be inflated to the same number if they have different loads?
Driver's front is 2007 lbs, Passenger's is 1720 lbs.
Does ride improve as pressure is lowered?
Should the rear duals all be inflated to the same pressure?
Driver's rear is 5534 lbs, Passenger's is 5181
First, you need to figure out why there is such a difference left to right and do what you can to even things out. Those numbers sound out of bounds and I think you could be headed for trouble in an emergency.
