JohnDoe's avatar
JohnDoe
Tire pressure when traveling
I have the Tire pressure monitoring system < my tires are load range E and inflated to 80 PSI which is what is called for on the tires, when I am traveling they heat up to where the tire pressure is over 90 psi and that is with outside Temperature is in the 60 to 70 degree range, going south in November, I get concerned that the pressure is way to high, Opinion,s
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
