Tires inflated to the maximum pressure stated on side wall , how much will that pressure increase from the heat of the road ? for you folks that have tire monitors , Thanks
Note that if you run your tires over inflated based on the load they carry, you will tend to wear out the center of the tread early, opposite for under inflated.
