JohnDoe
Nov 03, 2013Explorer
Tire pressure
Tires inflated to the maximum pressure stated on side wall , how much will that pressure increase from the heat of the road ? for you folks that have tire monitors , Thanks
Popsie wrote:
Note that if you run your tires over inflated based on the load they carry, you will tend to wear out the center of the tread early, opposite for under inflated.
