anon125
Mar 29, 2015Explorer
tire pressures
We just got michelin xze tires. The tireman wanted to put the max air in them , 110psi I think. But our experience is that hard tires rattle the mh on the bumpy main roads like the i5. So we said 9...
phillyg wrote:
Your PSI should be adjusted to the tire mfgrs. load range table. You can't know for sure without knowing the weight on each axle.
