Braces's avatar
Braces
Tire to Wheel well clearance
Need to gain about 1" more clearance. Would adding a leaf to the springs be a realistic fix? Montana 5er. Already on top of axles. Maybe a 1" spacer of some sort between spring and axle. Newby member -Subject didn't post--CLEARANCE BETWEEN TIRE AND WHEEL WELL. Easier to fix trailer than do this post. Old dog new tricks. Sorry
  • I don't know why that line repeated. I've posted on other sites before but this one is giving me fits.
  • More info on post. Trailer not near to max. wt. Only 10,000 mi. or less so I don't think springs are flattened. Possibly only assembled to minimum clearance at build. Tires have hit top of wheel well,probably only on big bumps. CRE3000 unit. Someone mentioned bigger equalizer, more info on that please. Talked with Dexter tech today, he advised against a spacer between axle and spring. Will question about longer shackles. Thanks, more suggestions welcomed.
    well,probably on big bumps. CRE 3000 unit. One responder mentioned taller equalizer,more info on that please. Talke
  • He discusses clearance, but I suspect he's looking at a 1" lift. Maybe to level the ride? I don't know. But one way to lift 1" is longer shackles.
    Spacer block will be pretty expensive as new U-bolts would be needed and they ain't cheap!
  • I gained that much by going to a different (taller) equalizer. Very cheap and easy change!
  • Why is the clearance so tight? If it's overloaded, making more clearance doesn't fix the real problem.
  • Probably a new spring pack is in order and go up a few hundred pound rating.
  • It's possible that your springs are sagging and need to be replaced. As the springs fatigue they flatten out and that would explain your lack of clearance.
    You don't give any details so it's hard to say. The more details the better advice you'll get.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
