pianotuna
Sep 02, 2020Nomad III
3000 watt are not often maxed out. Mine caught on fire, due to a rather nutty design "feature". Hence moving to a higher voltage is desirable.
Actually my microwave is the largest demand (1591 watts, measured). I wanted to be not having to load balance, so I can run the toaster and the microwave at the same time.
If I were starting over, I'd definitely go 48 volts.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
