D_E_Bishop
Apr 07, 2018Explorer
Go outside, open the access panel door and lift the lever on the PT valve. If very hot water comes out, the problem is most likely with one of the shower control valves or the bypass valve. Check them for proper position. If the water is lukewarm you friend has a problem.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
