alfredmay
Apr 07, 2018Explorer
I know that some newer Atwood water heaters and maybe others have a mixing valve. This injects cold water into the hot water stream as it leaves the heater. Doing this allows a 10 gal water heater to super heat the water and provide more than 10 gals of hot water. Check the water heater model number to see if this heater does have a mixing valve. The valve may be defective or clogged.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
