BFL13
Apr 08, 2018Explorer II
dougrainer wrote:Edd505 wrote:bdpreece wrote:
Couple of thoughts. As BFL13 stated check the bypass valves. Second thought check to make sure the outside shower is actually shut off at the valves rather than at the shower head.
My bet one of these fixes the issue.
Bypass valves or outside shower will not cause an extremely long Heating cycle. Doug
The rig is new, so I thought more likely the thermostat would be ok, but the owner is new to that rig.
I was thinking some cold water was getting in at the same time he was trying to heat it, delaying the heat up and it never getting fully hot.
I thought the by-pass valves might not be set right, but had not thought it through. So now my idea needs a new way for that to happen. Running water or a leak from the hot side? Not so likely with the water pump coming on. He would notice that! Or would it if on city water? He is in a "camp" in the OP.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
