seporterky's avatar
seporterky
Toad tail lights not working
Working on a 2004 Fleetwood Discovery 39L with 2016 Ford Explorer toad. Tail lights on the toad not working. The problem appears to be no voltage at the tail/running lights pin on the Motorhome. Brake and turn signals work fine. Does anyone know where the tail light connection on the trailer hitch connects? Haven’t been able to find a schematic.
Also the rear roof running lights do not work. Related? All other lights on the MH and toad are good.
Any suggestions will be appreciated.
Stan
  • x2 theres a fuse some where , found mine one time same problem only took couple hrs.
  • Check fuses on MH. I think that travel tail fuse different than break & turn signal.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
