j-d's avatar
j-d
Explorer II
Aug 24, 2017
Today's Coleman Mach 15 Incident
We're right on a beach in FL, temp in the upper 90's with high humidity, bright sun and no shade. Our A/C had been keeping the coach on the warm end of the comfortable range, around 80. Till this afternoon. It'd run 10 minutes, compressor shut down, need 20 minutes to recover on High Fan Only, then run another 10 minutes. I went to the roof to do two thingd:
1. Verify that the Evaporator and Condenser Coils I'd recently cleaned, were still clean.
2. Test and possibly Replace the Compressor RUN Capacitor. This is a 40 uF capacitor, and I had a new spare. Old (from 2002) capacitor read 36 uF on my Fluke 12. New read 40. I don't think 10% off spec is too much, but I installed the new one and buttoned the unit up.
It has run since, blows colder, and sounds better. I can only figure the capacitor has gotten "tired" without total failure. It isn't swollen or leaking.
VERY glad I had a spare!
  • I am not sure . . . :S . . But I think the Capacitor is only "used" to start the compressor. After the compressor is running, the capacitor has no effect. May be a real electrical engineer can verify.
  • j-d's avatar
    j-d
    Explorer II
    That's sorta what I was thinking. Breaking down hot. Definitely reduced the effectiveness of the compressor. A/C is quieter inside and outside the coach than it's been for awhile.
    I'd like to connect the FAN side of this new Capacitor too, but it's confusing to me. The original ones are two separate capacitors, but there is no jumper between them to serve as a COM terminal like the new two-way capacitor has.
  • I bet if you put the old cap in an oven and warmed it up to 150F and tested again, you'd find it was more than 10% out of spec.
    Glad to hear it was a quick fix for you!
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
