West_BeachhouseExplorerJul 03, 2016Toilet base leakHas anyone experienced an intermittent fresh water leak at the base of the toilet/floor? Besides tightening the bolts, what other suggestions would you recommend? Thank you. West Beachhouse
Sam_SpadeExplorerJul 04, 2016AND.....make sure you aren't leaving too much water in the bowl while going down the road.I was just about to start tearing things apart looking for a leak when I realized that it only showed up after being moved.Leaving only a couple of ounces in there to cover the seal solved the problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
