Has anyone experienced an intermittent fresh water leak at the base of the toilet/floor? Besides tightening the bolts, what other suggestions would you recommend? Thank you. West Beachhouse
I had this problem and replaced the seal twice and then did some closer inspection and found that the base that holds the retaining bolts was cracked. Went to Lowe's and got a new one. Cut the old one out with my Dremel tool. Glued the new one in. Problem fixed. Not a fun job but necessary. Busyguy
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
