Has anyone experienced an intermittent fresh water leak at the base of the toilet/floor? Besides tightening the bolts, what other suggestions would you recommend? Thank you. West Beachhouse
When I repaired ours, there were threaded flanges in both male and female, as well as apparently the glued versions busy mentions. I got the threaded one the RV parts shop said was the most popular, took it home and it fit.
Potential problem is, if the floor rots out, weight of toilet with occupant crushes down onto the black tank and can crack it.
Thetford sells a "pedestal" that's a spacer base with a much larger footprint than most toilets. It can help spread weight out across the floor.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
