John_Joey
Sep 02, 2014Explorer
You'll find out it could be many things. TP stuck in the groove not allowing the paddle to close. Bend a butter knife ninety degrees and gentle scrape the groove. Or maybe even hard water crystals, pour some full strength vinegar and let it sit as long as you can. Maybe the rubber itself is hard, some use ATF and let it sit with success.
Or as you said it needs lubricant, Vaseline seems to do the trick.
