huskyfan68
Oct 12, 2020Explorer
toilet seal
in 20+ camping years- never saw this (or had this issue) My RV toilet does not hold water- (it flushes)- but i know I've always hit the foot pedal slightly and filled up the bowl at times- It works...
Ron3rd wrote:HappyKayakers wrote:
Recently had the same problem with mine. Thetford Aqua Magic II. Had to turn off water, disconnect lines, remove toilet from floor flange. Flip toilet upside down, separate toilet in the middle and replace seal. Reverse steps. If you get the seal kit, also replace the floor seal at the same time.
Depends on the model. On my Dometic with the China bowl, you just hold the pedal down to move the ball over and reach in and pull the seal out of the groove. Takes about 20 seconds if you're very slow.
Other models might require some disassembly.
